Message 1 of 6
By smart hub 2
I am having major problems with the Smart hub2 with port forwarding for no reasons the posts seem to close themselves also when I try to delete port rules they wont delete
This hub is a complete nightmare. If I use upnp enables on cameras and hub 3 out of 4 cameras work ?? Then if I look on port forward rule there are about 30 of them ???
any ideas ?
is it best to ditch the bt hub and get a WiFi 6
will the by mesh disks work with a say a ASU’s ax3000
5 REPLIES 5
Message 2 of 6
Re: By smart hub 2
I had to reboot my Smarthub 2 in order for it to forget the port forwarding settings.
In terms of security and simplicity I would recommend a vpn server for accessing your iP cameras remotely.
Message 3 of 6
Re: By smart hub 2
Rebooted mine today and the disks don’t work now and they refuse to connect back up I hate the not so smart hub 2
Message 4 of 6
Re: By smart hub 2
A vpn will make life much easier and secure for you
Message 5 of 6
Re: By smart hub 2
Hi I will give it a go is it similar to setting up a ddns
and will it be compatible with my cameras ?
Message 6 of 6
Re: By smart hub 2
Yes it will mean you will be able to access your lan securely when away from home. You could always use a ddns like No-ip
