pigsty213
Message 1 of 2
CALLER DISPLAY ON BT 4000 PHONE
I cannot get caller display on my BT 4000 phone although I have the service.
I have reset the settings on the phone and dialled "234", which didn't seem to work either.  I have even turned off the plug then turned it on again.
I am getting really frustrated.
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: CALLER DISPLAY ON BT 4000 PHONE
try dialling *#234# and listen to the announcement.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
