teh10261
Message 1 of 3
CAN BT increase my upstream line speed?
Hi,
I have 'unlimited faster broadband from BT' which basically gives me the performance below. typically I get about 18 Mbps or thereabouts most days and anywhere between 0.75 and 1.1 (on a good day) upstream
I work from home and need to use google hangouts/webexs and the performance is poor. I suspect the upstream is killing me. Is there anyting BT can do to improve the upstream speed?? even if they could get it up to about 3-4 mbps that would be enough. I spoke to an open reach engineer and he seemed to suggest that the upstream speed could be tweaked by my ISP. Does any one know anything about that or if that is possible given my line profile?
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
VDSL Range A (Clean)20151.20.8--Available----
VDSL Range B (Impacted)17.87.31.20.6
2 REPLIES 2
Webby
Message 2 of 3
Re: CAN BT increase my upstream line speed?
As you're getting speeds pretty much exactly as the estimate predicted, there's nothing that can be done to increase your upload speed.
john46
Message 3 of 3
No ISP has the ability to make changes to the fibre services only Openreach can reset lines and then only if a fault is found as already posted your upload is within the estimates so there is nothing anyone can do to increase upload speed
