moorhouse
Newbie
Message 1 of 2
CAN YOU CHANGE OGM REMOTELY FROM GRAPHITE 1500 ANSAMACHINE
Does anyone know whether it is possible to change your outgoing message remotely on a Graphite 1500 phone.    I have searched the manual and can only find details about how to play messages, turn answer machine off and on, delete messages etc.   On my old BT ansamachine you could remotely change the outgoing message if required but this does not appear to offer that feature which is very useful.    I have checked my messages remotely but now need to change the outgoing message.
Any ideas?   I am unable to get home to change the message and need to change it urgently
any help would be gratefully received.
Many thanks
1 REPLY 1
Message 2 of 2
Re: CAN YOU CHANGE OGM REMOTELY FROM GRAPHITE 1500 ANSAMACHINE
The manual says
Operating your answering machine from another phone
1. Call your BT Graphite 1500. When you hear the outgoing
message, press the * button.
2. The machine announces, “Please enter your security code”.
Use the phone’s keypad to enter your 3-digit PIN (default PIN:
000). The machine announces, “You have ‘x’ new messages”,
and they are played.
3. Using the phone’s keypad you can replay, pause, skip or delete
messages and adjust settings.
You can stop the incoming message playback using option 7.
Option 1 says menu, so there may be more options from there.
