Message 1 of 3
CAT 5 or 7 Ethernet Cable
Hi Folks,
Just had BT Full Fibre (Fibre to the House) installed. All works great but I need to install a longer Ethernet cable than the one supplied to reach my NAS etc.
Please excuse me if these are daft questions but…
1) The Ethernet cable supplied has red ends - does this mean anything or is the connector colour irrelevant.
2) What is best make/brand of Ethernet cable to buy?
3) Reading online the recommendation seems to be CAT 7 - does this work with BT OK as I assume the cables they supply are CAT 5?
Thank you for your help.
Kind regards
Paddy
2 REPLIES 2
Message 2 of 3
Re: CAT 5 or 7 Ethernet Cable
1. Colour is irrelevant.
2. Don't buy the cheapest or the most expensive.
3. Cat 5e would be sufficient
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 3
Hi Stevebrass,
Thank you for your swift response. All ordered and on its way.
Many thanks
Paddy
