Message 1 of 5
CI Module
I purchased a new Smart TV at the weekend (LG 32LN578V) and connected it to my BT wifi wirelessly. However, when I switched the channel to BT Sport a message came up on the screen saying something like 'No CI Module'. I do not have BT Vision or any of the other (Sky, Virgin) TV packages but had assumed it would just be a case of wirelessly connecting to the router and away I go. No such luck! Is there another piece of kit that I need to add? Can I download the BT Sport app on to the TV and watch there. I'm not very techy-minded so all advice appreciated!!
4 REPLIES 4
Guru
Message 2 of 5
Re: CI Module
You need to add a BT Vision Box, Youview Box or Sky Box.
Not available through the CI Slot
Message 3 of 5
Re: CI Module
Thanks StewM. Do you know if I can download the BT Sport app on my Smart TV and watch there?
Guru
Message 4 of 5
Re: CI Module
Your TV needs a browser to do that and I am not aware of any TV that could download the app. The use of smart TV's have been covered here https://community.bt.com/t5/BT-Sport/BT-Sport-on-my-Samsung-Smart-TV/td-p/881972
Message 5 of 5
Re: CI Module
Hi Brian
If you have a Kindle this will connect to an LG Smart TV. Good quality stream.
