DanLines
Message 1 of 5
CON-0113
Like many other people, apparently, I am getting this when I try to register for the BT Sport App:
There's been a technical error – but you can still place your order online.
To order a Broadband and Calls package with optional TV, click here
To add BT Vision to your existing BT broadband package, click here
To order a new phone line, click here
To switch your calls back to BT Click here
Ref# CON-0113
There are a few fixes floating around (make sure you have a the account number as the contact in your profile, make sure you're the account holder etc.) all of which I've tried to no avail.
One hour to go to the start of the Premier League season and it looks like BT may have scored the first own goal of the campaign.
Any help out there?
Tags (2)
4 REPLIES 4
DavidM
Moderator
Moderator
Message 2 of 5
Re: CON-0113
Hi DanLines,
Thanks for posting. I can look into this for you if you wish. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile. Once I have the details we'll take it from there.
Cheers
David
DanLines
Message 3 of 5
Re: CON-0113
Yes, now sorted, thanks.
Bit late for the Liverpool game, but there you go.
Indrid
Message 4 of 5
Re: CON-0113
Hey DanLines, how did you get this sorted?
AlexandraT
Message 5 of 5
Re: CON-0113
Hi, I'm trying to make a moving home order. I'm getting the same error. Can anybody help?
