zjc100
Message 1 of 39
Cabinet Full
Hello
My cabinet appears to be full where I am moving to for Fibre. The ADSL wholesale checker says waitlist.
Just wondering is there anyway of finding out if capacity is going to be added or not and what is this illusive waitlist. BT sales tell me they don't know of such a thing.
38 REPLIES 38
Webby
Message 2 of 39
Re: Cabinet Full
What exchange and cabinet number are you served from?
zjc100
Message 3 of 39
Re: Cabinet Full
Hi Webby
Thanks for replying.
Details are
Exchange CROFTON is served by Cabinet 7
Webby
Message 4 of 39
Re: Cabinet Full
I suggest contacting Openreach via their website.
zjc100
Message 5 of 39
Re: Cabinet Full
I did contact them. There reply basically said they don't have any information and keep checking with providers. Doesn't really help
pompey1898
Recognised Expert
Message 6 of 39
Re: Cabinet Full
Hi,
That happened to me.  All you can do is keep checking https://www.btwholesale.com/includes/adsl/main.html daily until someone gives up their connection or capacity is increased.  Banging on at OR and my BDUK scheme got me absolutely nowhere.
zjc100
Message 7 of 39
Re: Cabinet Full
Hey thanks for the advice​. How long did you end up having to wait in the end?
john46
Message 8 of 39
Re: Cabinet Full
Unfortunately all you can do is keep checking for availability as it may only be an additional card fitting witch is a fairly quick upgrade or if it is an additional cabinet then the wait is unknown
zjc100
Message 9 of 39
Re: Cabinet Full
According to what I can find online the current cabinet only serves 250 properties and the max capacity is just above 250 im hopful a new card is on its way. Reluctant to sign up to ADSL for fibre to become available and not be able to benefit from the cheaper deals offered to "new customers"
Webby
Message 10 of 39
Re: Cabinet Full
ECI cabs have a max capacity of 256 subscribers I believe.
The cab served 260 lines at the time it was activated in 2013.
