Message 1 of 38
Cabinet Installation
Hi
The estate I live on seems to be supplied directly from the exchange.
When it was built, would it have been up to the builder whether a BT cabinet was installed or BT?
Checking on SuperFast Essex site, it seems that we are an island of single figure broadband whilst all around us is pushing 40Mb.
I would just like to know who would have made this short sighted decision.
37 REPLIES 37
Message 2 of 38
Re: Cabinet Installation
it would probably have been standard practice not to install a cabinet and connect the house near the exchange direct.  normally people conencted like that have enjoyed faster broadband than most and now they cannot get fibre until openreach erect a cab outside the exchange
Message 3 of 38
I suppose it could have been faster back when the estate was built but now it is in the dark ages (7Mb).
I checked the BT ADSL check and it says I should be only getting 3Mb so I should be thankfully.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+Up to 3--1.5 to 5.5Available
ADSL MaxUp to 2--1.5 to 4.5Available
WBC Fixed Rate1 ----Available
Other Offerings
Copper Multicast------Available
According to a chart of ADSL and ADSL 2+, I should be getting nearer 23Mb considering the distance away.
Graph of ADSL2+ and ADSL speed against distance
Any idea why the checker shows such a low speed?
I am glad I am only renting as nowadays not having fast broadband will knock the price of a house/flat down.
Message 4 of 38
can you post the adsl stats from your hub?
are you using the test socket with a new filter?
Message 5 of 38
20:21:35, 09 Jun.( 2580.720000) DSL noise margin: 23.00 dB upstream, 6.30 dB downstream
20:21:35, 09 Jun.( 2580.640000) DSL line rate: 448 Kbps upstream, 6720 Kbps downstream
No I am not using the test socket with new filter
Message 6 of 38
from your stats you are on adslmax and not adsl2  as your exchnage has been upgraded moving to adsl2 should increase your conenction speed and would certainly increase you up speed
have you tried using test socket with a new fillter to see if that improoves your current conenction speed - especially if you have extension sockets
Message 7 of 38
I assume they are not moving to adsl2 as everyone wants fibre.
I will try my socket with a new filter when I get home.
I have no extension sockets.
Message 8 of 38
BT do move customers to customers adsl2 but it can take a while after exchange upgraded. See what stats you get when connecting to test socket then assuming as goods before then I think we can ask mods to see if they can get you upgraded to adsl2. At worst your speed will be about the same but up stream will probably increase by about 100%
You may need a new contract to get upgraded but mods would advise you
Message 9 of 38
Hi there
I bought new filter and plugged into test socket.
Here are the stats
13:39:21, 13 Jun.(50261.170000) DSL noise margin: 23.00 dB upstream, 6.00 dB downstream
13:39:21, 13 Jun.(50261.090000) DSL line rate: 448 Kbps upstream, 7008 Kbps downstream
It would be nice to be upgraded to ADSL2 if fibre is not coming soon.
Message 10 of 38
stats look good and a bit more speed  see if mods can get you move to adsl2  mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
