imperial
Message 1 of 3
Cabinet Upgrade
Hello - Would someone be able to tell me if and when my cabinet may be upgraded? I'm in an enabled area at exchange level and surrounding streets have FTTC but my cabinet seems to be destined to remain in the broadband stone age.
PAVILION PLACE, BILLERICAY, CM12 0ET on Exchange BILLERICAY is served by Cabinet 45
2 REPLIES 2
jac_95
Guru
Guru
Message 2 of 3
Re: Cabinet Upgrade
Your Cab is being upgraded by the Superfast Essex BDUK programme. Their website says work on the cab in underway and may be available from 2 to 6 months time.
Source: http://www.superfastessex.org/where,whenandhow.aspx
pippincp
Sage
Message 3 of 3
Re: Cabinet Upgrade
As your cabinet upgrade is being handled by the Superfast Essex BDUK programme then they are the only ones who can give you further info.
Use the link given by @jac_95  for further enquiries.
