lowsonfordllama
Message 1 of 2
Cabinet location
Please can anyone help me find the cabinet location for B95 5HG.
I did try some of the previous links but to no avail . We are out in the sticks with overhead phone lines!! Help grat
efully accepted
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: Cabinet location
Hi and welcome to the forum.
I am afraid your cab location is not something that is available in the public domain, however have you tried the link HERE// this should show what cab (PCP) you er connected to, then its down to detective work yourself to try to locate, maybe via google map?
You say that you are out in the sticks fed over head, I suspect that will only be the last mile or so and your line would come off a pole which is fed via an underground cable from the Cab.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
