DavidCo
Expert
Message 1 of 4
Cabinet misconfigured?
This is a strange  query and not a comlaint?
I have a rock solid data set on Infinity1
I am about 450M line length.
However the Cabinet data gives a different picture.
Somebody I know lives across the road (30M) from the cabinet has almost identical Hub data as I do (Max data is 2Mb higher)
Of course the Cabinet data is identical.
Quite sometime ago I mentioned this to  a 'visiting' emgineer, and he had a 'look' at the cabinet.
His response, from memory, was something like -
"Why have they done that, they are only using XX number of ports. They will have to sort that out sometime"
Didn't bother me, after all I was getting 40Mb anyway.
But reading the comments about "up to 52mb" again and again it would seem that the 52Mb will never be applied due to the Cab Data.
Is there a way of finding out if the Cab config' is ever going to be dealt with?
I do have an additional 6Mb Max - Actual. Noise margin of 8.3
David
3 REPLIES 3
John25Roberts
Message 2 of 4
Re: Cabinet misconfigured?
Cab Misconfigured, I don't understand what you're talking about?
Your line has a Max Rate of 46/9, which is well above your Clean Line Range Estimates.
What the Engineers talking about, 'They are only using XX number of ports'. When Openreach commision a DSLAM they won't install and activate all the Fibre Cards until there's a demand for them. It's common for them to only activate 2 to start with.
What exactly is it you're trying to achieve?
licquorice
Message 3 of 4
It would appear the OP is capped at the old Infinity 1 rate of 40M rather than achieving his full potential of 46M. Others may be similarly capped.
DavidCo
Expert
Message 4 of 4
Sorry not to get back sooner, I did not get any notification.
That is exactly my point.
'MyBT' shows me upgraded to 50/10 inasmuch as I get 100MB cloud.
So I should, I think, be getting an increase.
