OzWald595
Message 1 of 5
Cable from Optical Modem to Hub
Dear All,
I am having a FTTP connection installed in a couple of weeks.
I would like to have the optical modem installed in a separate place from the hub (circa. 15m away).
Reading the installation manuals available online, they are quite specific about the use of a "red-ended" cable between the modem and the hub. Is this a special cable or can I use a standard ethernet cable (Cat 5?) between the two?
Many thanks
4 REPLIES 4
john46
Message 2 of 5
Re: Cable from Optical Modem to Hub
it is a standard ethernet cable
OzWald595
Message 3 of 5
Hi john46,
Thank you for the quick reply.
With regards the proximity of the modem to the hub, I have read this:
http://bt.custhelp.com/app/answers/detail/a_id/45373/346
"2. The Hub and the Openreach fibre modem need to be next to each other, and both need a power socket"
Is this necessary? What are the reasons for this requirement?
Many thanks
john46
Message 4 of 5
No it is not necessary as the article goes on to say the hub can be up to 30 m away using a data extension kit which the engineer can fit during the install
gg30340
Message 5 of 5
They can be even further than 30m apart if needed. The only reason BT say 30m is because that is the length of the data extension kit they sell.
