Message 1 of 5
Cable to land line phone
My BT Decor 2500 phone only gets a line signal from a BT junction box using a long lead.
A short lead does not work. I've tried many.
Has anyone come across this before?
4 REPLIES 4
Message 2 of 5
Re: Cable to land line phone
sounds more like the wiring in the shorts leads is not the same as the wiring in your long lead.  distance from phone socket should not affect getting a dial tone or not
Message 3 of 5
@neatetown
If you are still having issues, give Discomm a call, as they are a BT spares supplier, and should be able to help you with the correct short cord. As @imjolly  has said, your short cords may have the wrong pinout.
Message 4 of 5
Thanks imjolly.
Message 5 of 5
Many thanks Keith will contact Discomm as suggested.
