Alison332
Message 1 of 4
Call Barring
Does anyone know the code for barring mobile numbers outgoing.  The only code I can find is to bar national, international and mobiles but I dont want to bar national calls.  Any suggestions
3 REPLIES 3
caerdydd
Message 2 of 4
Re: Call Barring
Unfortunately there isn't an option just to bar mobile numbers.
It's just option 2 (National, International & mobiles) or nothing.
Message 3 of 4
Re: Call Barring
You can bar them if you use broadband talk, but not normal PSTN. I don`t think the exchange software is smart enough.
inthedark
Newbie
Message 4 of 4
Re: Call Barring
I would also like to bar outgoing mobiles numbers (07) ask I have teenagers!
I have just moved over from TalkTalk where you can bar 07 numbers.
As caerdydd mentioned, it is not possible with BT.
I was told when I applied for BT's 'get first two months free' package that I could bar 07 numbers!
Not good BT
