tomtomtom
Newbie
Message 1 of 3
Call Divert Setup
Hi
When trying to setup call divert using *#21# I get the message 'sorry the service requested is unavailable. Thank you for calling'
Anyone got any ideas?
Thanks in advance
Tom
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Call Divert Setup
Hi and welcome.
To set a divert up (diverts all calls) it is *21*(phone number you want to divert calls to) then #
The user guide is here if it helps
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Hi a simple question is have you actually ordered call diversion from the announcement you are hearing it sounds like it is not active on your line it is a service that has a monthly charge
