Message 1 of 5
Call blocking with Digital Voice
I have a BT "Premium Phone with Voice Control and answer machine with TrueCall technology". This has worked marvellously over the last few months in blocking unwanted calls.
Will it still work when I am switched to Digital Voice?
4 REPLIES 4
Message 2 of 5
Re: Call blocking with Digital Voice
Yes, just plug it into the phone socket on the back of the smart hub 2.
Message 3 of 5
You need to make sure your existing phone answers call before the DV   you need to go to MYBT then DV then manage and then  set DV to answer at max number of rings so existing phone answers fist
Message 4 of 5
Thanks. I asked as I have read that sometimes Caller ID does not work with Digital Voice.
Message 5 of 5
Yes, provided that you make sure that its enabled on the BT Digital Voice instructions.
