Message 1 of 4
Calling abroad
Hi all. Following on from my wifi calling question. Do bt have an add on or package for calls to australia. Or would it be better to use a second sim in my a21s. I know i can get something with inclusive minutes to aus.
3 REPLIES 3
Message 2 of 4
Re: Calling abroad
not sure why you don't try what  was suggested on your other post - use something like whatsap/facebook messenger/apple facetime/google duo for starters.  you both need the app installed on your devices then all your calls including video calls are free
Message 3 of 4
Re: Calling abroad
FaceTime works well on Apple mobiles, and even the iPad, but doesn’t work on Android...yet.
There’s a Google equivalent for Android. This may be better than a dual sim on your A21S.
Google Duo, among others?
Then there’s Friends and Family International for your BT landline, if you have one. Works Well.
Message 4 of 4
Re: Calling abroad
Thank you
