Message 1 of 7
Can Fibre “free run’?
I’m very happy with the FTTP speeds I get: 900mb+ down & 110mb up.
I’m guessing both speeds are restricted in some way; is it possible to let both up & down run freely i.e. with no limits?
Will BT allow this? Who should I ask?
Kind Regards
Hugh
6 REPLIES 6
Message 2 of 7
Re: Can Fibre “free run’?
No.
Message 3 of 7
I'm sure 900Mbps must be very limiting for you!!
Message 4 of 7
Simply a question; sarcasm is not needed.
Message 5 of 7
The speed is governed by hardware and software limits. My mate works for BT wholesale and be has a G-Fast connection at home with all limits removed and no contention. Obvious this is all for work purposes but he's synced at a gig
Message 6 of 7
That sounds great! Thanks for the reply - Hugh
Message 7 of 7
Which will not happen for a BT paying customer so the answer to the questions asked "Will BT allow this? Who should I ask" is still no.
