DavidMc1984
Message 1 of 8
Can I be switched to ADSL2+ now please
Hi, ADSL2+ is avilable in my area now can I be upgraded please?
Telephone Number *********** on Exchange DUNOON is served by Cabinet 16
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)8062.72020--Available
FTTC Range B (Impacted)76.551.92015.8--Available
WBC ADSL 2+Up to 1--1 to 3.5Available
WBC ADSL 2+ Annex MUp to 1Up to 0.51 to 3.5Available
ADSL MaxUp to 1--0.75 to 2.5Available
Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
7 REPLIES 7
imjolly
Message 2 of 8
Re: Can I be switched to ADSL2+ now please
from reading you previous posts I doubt adsl2 will give you much faster down speed but it will increase your up speed.  the consequence maybe a less stable connection as adsl2 is more aggressive on any line noise which appeared to have increased your noise margin to 9db  see what mods think   they will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
OlgaC
Moderator-Retired
Message 3 of 8
Hi DavidMc1984,
Thanks for your post. Can you send me in your details using the "Contact The Mods" link found in my profile and I will see if upgrading you to ADSL2+ will be best for you.
Thanks,
OlgaC
DavidMc1984
Message 4 of 8
Thanks for replies, details sent
DavidMc1984
Message 5 of 8
Hi, just seeing if there;s any update to this, Received a call from bt before christmas saying I will be switched over soon but I don't think there's been much change, the download and upload speed has dropped slightly, so the upgrade order is still going through since it's the busy period?
imjolly
Message 6 of 8
can you post the stats from your router please  quite possible a delay due to holidays
DavidMc1984
Message 7 of 8
Yea figured it would be busy at this time so just checking to see if there was any update.
09:40:06, 24 Dec.(522575.130000) DSL noise margin: 25.00 dB upstream, 6.10 dB downstream
09:40:06, 24 Dec.(522575.060000) DSL line rate: 448 Kbps upstream, 3968 Kbps downstream
imjolly
Message 8 of 8
 Speed better than estimated so hopefully adsl2 will be as good if not slightly better
