Message 1 of 8
Can I block a certain website?
Is it possible to block a website from the internet. I'd like to ban facebook if thats possible.
Regards
Sakil
7 REPLIES 7
Message 2 of 8
Re: Can I block a certain website?
It all depends on what router you are using, and how many computers you are trying to block.
If you can provide this information, then someone might be able to help. Thanks.
Message 3 of 8
Kids spending too much time on it? Worried about privacy issues?
My immediate thought was use the hosts file if you have Windows systems on desktops/laptops at home.
Have a look here:
http://www.guidingtech.com/4868/edit-hosts-file-block-websites/
But if it's kids with handhelds or other non-Windows devices that can access the net off your home LAN, then that won't work.
As Keith says, please send more information.
Distinguished Guru
Distinguished Guru
Message 4 of 8
Your browser might help. For example, while Google Chrome doesn't have a built-in facility there are extensions which claim to do it. "Nanny for Google Chrome" says it can block chosen websites completely, at particular times, or after a specified period of continuous connection. It looks good, but I can't advise for or against as I've had no need to try it.
There may be similar add-ons for other browsers. Try an internet search.
Message 5 of 8
the hots file is probs the best way if you only want to block it from computer but of cause it wont block phones using 3g or anythng like that
Message 6 of 8
sorry for the late reply
I require it to block on a laptop and a desktop. Currently I'm using the homehub v2.
Message 7 of 8
Provided that you are the only person that has admin rights on the computers, then you can use a free service called OpenDNS.
You can set up a free account which enables to to block certain types of web domains, and specific domains.
Full details are here http://www.opendns.com/home-solutions/parental-controls/
On the site it tells you how to set-up your computers network settings, you cannot do it on the router because the home hub 2 does not allow you to change DNS settings. Its quite simple to do, but if another person had admin rights, then they can undo the settings on the computers.
Its very effective and you can view a list of the sites that have been visited, and those that were blocked.
If you need any help, let me know.
Newbie
Message 8 of 8
To block certain websites on your PC, here' s the trick (for Windows):
Step 1: Click the Start button and select Run. Now copy and paste the following text in that Run box:
c:\WINDOWS\system32\drivers\etc\hosts
Choose “Notepad” to open it.
Step 2: Go to the last line of the file, hit the enter key and type in the following format:
127.0.0.1 xxxx.com
Eg: If you want to block facebook.com and myspace.com
127.0.0.1 facebook.com
127.0.0.1 myspace.com
Step 3: Save the modified file
That’s it. None of the above sites can be visited on your computer.
One per line if you want to add more web sites.
In this way you can only block website one by one, if you want to block websites in large scale, you can use a professional web filter which will help you easily block websites by keywords or URL.
