Can I connect 2 hub 5s (Slaves) to 1 master hub 5?
Solved! Go to Solution.
Yes, if you intend using them as wireless access points/ethernet switches. Give each a different IP address outside of the DHCP range of the master hub, disable DHCP on the slaves and connect them LAN port to LAN port
