BuzzRog
Message 11 of 15
Re: Can I get BT Infinity in my appartment?
I've tried this and it tells me it's cabinet 37 on the Penn Exchange but other than that it just gave the same information as before. I've email'd BT Infinity to see if they can shed any light on it for me.
Thanks again!!!
Derrick
Checked2013
Expert
Message 12 of 15
Until the works have been completed you won't know what speeds you will get
BuzzRog
Message 13 of 15
Thanks for your help
dfenceman
Expert
Message 14 of 15
Thanks again!!!
Derrick
Hi BuzzRog,
And is cabinet 37 the one you are connected to ?  If so then there is no fibre cabinet planned for that PCP.
Which Penn exchange are you on ?
Exchange Search Results
 Exchange Name OLO County Region
PennCMPENWolverhamptonWest Midlands
PennyghaelWSPENArgyll and ButeScotland
PennalWNPNLGwyneddWales
PennantWNPNNPowysWales
PennSMPENBuckinghamshireSouth East
Best regards,
dfenceman
BuzzRog
Message 15 of 15
Hi
The exchange that I'm connected to is Penn Wolverhampton
Many Thanks
Derrick
