BuzzRog
Message 1 of 15
Can I get BT Infinity in my appartment?
Last week work started on installing BT Infinity to our estate. I live in an appartment and the tubing that the fibre comes down was installed to the BT floor box just outside my appartment. Does anyone know if I'll be able to get BT Infinity living in an appartment? Also does it look like it will be Fibre to our BT floor box then copper wiring to the appartment? And what speeds could I get up to if this is the case?
Many Thanks
Derrick
14 REPLIES 14
Helios
Message 2 of 15
Re: Can I get BT Infinity in my appartment?
How big are these apartments? As in how many high?
BuzzRog
Message 3 of 15
3 storey, ground, middle and top.
Many Thanks
Derrick
Mancunian01
Message 4 of 15
There's no reason why not.
BuzzRog
Message 5 of 15
Thanks for that. Peace of mind for myself as I'm desperate to get BT Infinity due to my slow broadband speeds. I take it would be fibre then through the copper wiring to the appartment? If this is the case do you know what's the best speed I could get using BT Infinity?
Many Thanks
Derrick
dfenceman
Expert
Message 6 of 15
Enter your phone number here https://www.btwholesale.com/includes/adsl/main.html  and paste the reuslts
Best regards,
dfenceman
BuzzRog
Message 7 of 15
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+ Up to 2 -- 1.5 to 4 Available
ADSL Max Up to 1.5 -- 1 to 3.5 Available
WBC Fixed Rate 2 -- -- Available
Checked2013
Expert
Message 8 of 15
If they only started preparing for Infinity then it will not show on the checkers yet if you can get Infinity, you will have to wait until the works is complete
BuzzRog
Message 9 of 15
Thanks for your advice.
Any idea what the fastest speeds I may get fibre then through the internal copper wiring into the apartment?
Many Thanks
Derrick
dfenceman
Expert
Message 10 of 15
Hi BuzzRog,
I should have said to use the address checker here https://www.btwholesale.com/includes/adsl/main.html .  Just enter your postcode.  If a DSLAM FTTC cabinet is installed or in the process of being installed in that postcode area then the DSLAM cabinet appears on the list of addresses within that postcode area.
Best regards,
dfenceman
