Message 1 of 8
Can I get fibre from my local box?
Just moved into a property and trying to get fibre broadband as my wife and I work from home. I’ve tried to check what broadband I can get, yet all suppliers say only up to 15mb.
Now when I complete the broadband checker, it says I can get fibre. Am I reading this right from the image below?
If I get my phone line updated, will that give me fibre?
7 REPLIES 7
Message 2 of 8
Re: Can I get fibre from my local box?
Fibre to the cabinet infrastructure is there in your area which also serves the property however it looks like the cabinet is full and therefore they have put a waiting list in place.
Message 3 of 8
updating phone like won't change the fact that you street cab is full and there is a waiting list for FTTC connection.. you need to keep checking the dslchecker and as soon as you see 'available' then place an order with your selected ISP
Message 4 of 8
Thanks for this. I assume this is what the “waiting list” is for?
Would there be actual waiting list with properties on there? How would I get on that waiting list?
or is it just a case of waiting for someone to move out of their home and cancelling their fibre before a slot is free?
Thanks for confirming.
Anonymous
Not applicable
Message 5 of 8
No actual list, will be down to whoever sees the availability first. So as @imjolly said, you need to keep checking for a slot & get an order in straight away.
Message 6 of 8
Thanks for confirming. I assume there’s no email alert when this happens?
Message 7 of 8
No
just checking dslchecker daily
Message 8 of 8
I ‘USED’ to work as a CSE for Openreach for over 20 years.
No ‘Waiting List’ ever existed, not in Openreach anyway. Maybe the CP had a Waiting List but I fail to see how it would work as they’d have to coordinate it with the list of every other CP out there.
**Disclaimer for the Moderators** Note I said, ‘USED’ to work as in past tense as in I don’t anymore so there’s really no need to spam me with messages.
