Adazrambo
Message 1 of 5
Can I get infinity or not?
If I put telephone number on openreach infinity checker it says I can order fibre, if I use post code checker it says it's over subscribed, I have family members around the same street who all have fibre optic but cannot get a clear answer from BT as their opinions all vary. Has anyone else experienced similar?
4 REPLIES 4
john46
Message 2 of 5
Re: Can I get infinity or not?
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Adazrambo
Message 3 of 5
Well here's the thing, we have just moved house and our phone line is being installed on Monday. I have been given a number but it's not officially registered yet. I have put my neighbors phone numbers through it and all say fibre is available, where as on the openrrach website if I used their post code it would say it's too in demand.
Ectophile
Distinguished Guru
Message 4 of 5
It may be that your postcode is split across two cabinets - in which case one could be full while the other has slots left.  The check using a phone number should be more accurate, as it will reveal the correct cabinet.
Adazrambo
Message 5 of 5
Thanks for reply - appreciated
