castlemaster
Message 1 of 7
Can I get interleaving disabled please
Hi,
Yes, I'm fully aware of the repurcissions, but can I get interleaving disabled on my line please.
Thanks in advance
6 REPLIES 6
imjolly
Message 2 of 7
Re: Can I get interleaving disabled please
Can you post stats from your router please
castlemaster
Message 3 of 7
Spoiler
xDSL
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OffOff
SNR Margin (dB)5.513.0
Attenuation (dB)58.531.5
Output Power (dBm)17.911.8
Attainable Rate (Kbps)2348756
Rate (Kbps)2432448
K (number of bytes in DMT frame)7715
R (number of check bytes in RS code word)1416
S (RS code word size in DMT frame)2.002.00
D (interleaver depth)82
Delay (msec)4.004.00
INP (DMT symbol)0.330.06
Super Frames1686609316866093
Super Frame Errors893784436
RS Words573447153143378017
RS Correctable Errors13146364593
RS Uncorrectable Errors20160
HEC Errors5027933530
OCD Errors50
LCD Errors50
Total Cells16446031370
Data Cells7942062900
Bit Errors442790
Total ES263830
Total SES11140
Total UAS613230
imjolly
Message 4 of 7
looks lots of errors how long is internet connection time - does not appear in stats
castlemaster
Message 5 of 7
About 5 days connected, not fussed about errors, want interleaving off to improve my game pings, aware of the effects thank you
NeilO
Moderator
Moderator
Message 6 of 7
@castlemaster Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
imjolly
Message 7 of 7
it was more the point that with all the errors it is quite possible that a short time after mods move latency to FAST that the DLM will move you back to interleaved to help your connection
just complete the mod form and they will get back to you
