Lscue
Message 1 of 4
Can I install infinity without PC just iPad?
Very simple question - and yes I have searched forum posts but could not find clear answer - can I install infinity 2 without a PC just an iPad? We've moved into 21st century and so don't have a PC or laptop anymore!
Thanks In advance
3 REPLIES 3
gg30340
Message 2 of 4
Re: Can I install infinity without PC just iPad?
Yes.
If you do the first thing you should do is turn off "Smart Set Up" on the Homehub as it can cause problems with tablets and phones.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Lscue
Message 3 of 4
Very good advice and quick response thanks so much! An engineer is coming so ill pass that on just In case !
jac_95
Guru
Guru
Message 4 of 4
Hi Lscue,
As well as what  has said, if you use your BT email then here's how to set it up on your iPad - http://bt.custhelp.com/app/answers/detail/a_id/46673/c/346,6588,6591#apple.
 Though you can also use the webmail platform via https://signin1.bt.com/login/emailloginform
If you need the IMAP or POP3 settings they are here: http://bt.custhelp.com/app/answers/detail/a_id/44917/c/346
I think that's all the basics you need to get started when your new Infinity connection is installed.
If there is anything else just pop back
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
