mentally_rich
Message 1 of 12
Can I upgrade broadband without extending contract?
I spoke to someone on online chat about upgrading from infinity 1 to infinity 2. They told me I had to take an 18 month contract to do this and this was the only option. Is this true? I've only started a 12 month contract. I presume that would be converted to an 18 month contract and the 18 months wouldn't be added on Smiley Surprised
I changed my plan with my mobile provider and it didn't extend my contract. Surely you can do the same with BT?
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: Can I upgrade broadband without extending contract?
Welcome to this user forum.
I will ask a moderator to comment.
PaddyB
Moderator
Moderator
Message 3 of 12
Hi @mentally_rich,
If you're upgrade from BT Infinity to Infinity 2, it does mean that you will enter into a new contract. The new contract is usually 12 or 18 months. The new contract term doesn't get added onto your existing contract but starts afresh from the date that the upgrade order completes.
You can place the upgrade order yourself by using the link -  Upgrade your BT broadband
PaddyB
XRaySpeX
Recognised Expert
Message 4 of 12
Are you sure you need to upgrade to Infinity 2? Are you hitting the Infinity 1 cap?
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Anyway BT is in the process of uplifting speeds on Infinity 1 to be the same as the present Infinity 2 for those users who would benefit.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
mentally_rich
Message 5 of 12
Thank you for the replies, I'll probably go ahead with it then. I'm on unlimited at the moment I just want the higher speed.
Keith_Beddoe
Message 6 of 12
I would check first, to make sure your line can support the extra speed, otherwise you would be wasting your money.
XRaySpeX
Recognised Expert
Message 7 of 12
Unlimited usage isn't unlimited speed!
gg30340
Message 8 of 12
That is not entirely correct, there are exceptions which may apply to the OP according to the moderators post No. 106 in this thread
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Free-speed-upgrade-for-Infinity-1-customers...
Who's eligible?
We'll only upgrade existing Infinity1 customers who'll see a benefit in their speed. Some are already receiving the maximum speed that their line can support.
Who's not eligible?
There's been some confusion around who'll be getting the speed boost. Many BT Infinity 1 customers will receive a Speed Boost but here are details of who’s not eligible:
     >Customers who are already receiving the maximum speed that their line can support, and who won't benefit from increased speed.
     >New or re-contracting customers who take our Infinity product after 28 September.
     >Infinity2 customers who call in to downgrade their service to Infinity 52mbps.
XRaySpeX
Recognised Expert
Message 9 of 12
@gg30340: So only if OP took Infinity 1 after 28 Sept does it not apply.
Let's just see if OP can benefit from it 1st before nitpicking.
gg30340
Message 10 of 12
You make a sweeping statement and when it is pointed out that it is not entirely correct you call it nitpicking. I call it factual but each to their own!
