Message 1 of 2
Can I use BT with FON mobile Wifi at the same time as my home Wifi?
I would guess that I can, but I wanted to check.
I have BT broadband but I'll be starting a new job soon where I have to travel a lot and was hoping to be able to use BT with FON, because unless I'm mistaken all BT customers get that as standard. But I also wanted to make sure the missus can still use the home Wifi while I'm gone.
Is that all kosher?
1 REPLY 1
Message 2 of 2
Re: Can I use BT with FON mobile Wifi at the same time as my home Wifi?
Yes, no problem at all doing that.
I would make sure that it all works before you start travelling, as its easier to sort out from home. Make sure you are opted it, and try it from your own BT Home hub BT Wifi signal first.
