FrintonFogey
Message 1 of 6
Can I use a Panasonic DMR-HWT150EB PVR with BT TV
I have the opportunity to acquire a Panasonic DMR-HWT150EB so wondered if I can connect my BT TV package instead of the supplied BT Youview box?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Can I use a Panasonic DMR-HWT150EB PVR with BT TV
No, it would not work, as the serial number would not be a BT YouView box. The serial number is used for licencing and copyright validation.
MrShpak
Message 3 of 6
I'm not sure. As there was a delay in delivery I have successfully used a talk talk box on bt. And I bet that Bt didn't have a serial number for it. The first time I run it it updated and all the talk talk branding was replaced by Bt. I now have the Bt box and all works fine. So I do think that as along as you have a subscription to Bt TV the box doesn't matter.
MrShpak
Message 4 of 6
Just one more thing. I just checked and I can confidently say it will not work as it doesn't do youview. See below.
Freeview Y
Freeview HD Y
Freesat HD N
Freeview + Y
Freesat + N
Hard Disc Size 500GB
YouView N
Freetime N
Freeview Play Y
4KMarty
Message 5 of 6
That's not true and you should be careful not to post inaccurate information which might lead to others to waste money.
Your TalkTalk box worked because it's a YouView box and all YouView boxes can be used BT, TalkTalk or any other ISP. But the Panasonic box is NOT a YouView box so it will not work with BTTV. At all.
MrShpak
Message 6 of 6
I corrected myslef after reading the box specs. The generic answer is any youview box works. And as Panasonic one is not a youview box (after I checked the specs) will not work as posted.
