peterjacobs62
Message 1 of 68
Can I use separate modem with new BT Smart Hub?
I just received new Smart Hub to replace my old Home Hub 2 which had a separate modem.  The Home Hub 2 was connected to the modem via ethernet which meant the modem could be in the study in the corner of the house where the master phone socket came in, whilist the Home Hub was in the middle of the house where I get wifi range and where all of my ethernet connections (for Sonos, amplifiers etc) originate from.
I would like the Smart Hub in the same place as the Home Hub was, ie. in the middle of the house, but it has an integrated modem and there is no phone connection there.  So:
1. can I disable the internal modem in the Smart Hub and connect it via ethernet to the old modem by the master phone socket in the study as before? or
2. use some sort of adaptor to connect the phone socket in the study via the ethernet to the phone port in the Smart Hub in the middle of the house? or
3. do I have to accept that the Smart Hub has to live in the study and I need to buy some sort of combined wifi extender and ethernet switch in the middle of the house?!
Help please!
67 REPLIES 67
DavidM
Moderator
Moderator
Message 2 of 68
Re: Can I use separate modem with new BT Smart Hub?
HI @peterjacobs62 and welcome.
The Smart Hub has an improved wireless connection so should be sufficint for your needs. You can always try Wi-Fi extenders if needed.
Cheers
David
peterjacobs62
Message 3 of 68
No, the Smart Hub in study covers barely half the house.  Is it not possible to use it with separate modem?
DavidM
Moderator
Moderator
Message 4 of 68
Hi @peterjacobs62,
Thanks for posting. The hub has a modem inbuilt and we wouldn't recommend disabling it and wouldn't support using a seperate modem. Your best bet would be to use extenders if you're having wifi problems.
Cheers
David
licquorice
Message 5 of 68
Surely the smart hub has a WAN port, or a LAN port that can be configured as a WAN?
peterjacobs62
Message 6 of 68
Smart Hub has 4 Ethernet ports so I could use my Cat6 network to use wifi extender but I also need at least 4 ethernet ports with this. Is there a wifi extender with multiple ethernet ports which is compatible and will retain all of the functionality of the BT Smart Hub?
licquorice
Message 7 of 68
Have you investigated if one of the Ethernet ports on the smart hub can be configured as a WAN port? If it can, you can just connect to the modem as before. Just because BT don't 'support' that configuration, it doesn't mean it is not possible. A simple ethernet switch could then be used to restore the number of Etehrnet ports required. Alternatively there are combined wifi extenders and ethernet switches available, the Edimax 7228Apn for one.
licquorice
Message 8 of 68
It would appear Ethernet port  4 can be configured as a WAN port to connect to your modem.
peterjacobs62
Message 9 of 68
Thank you for this - how would I go about configuring in that way?
licquorice
Message 10 of 68
Sorry, I'm afraid I've no idea, I haven't got a smart hub. I just noticed in this document it shows LAN port4 as a WAN port http://btsupport.custhelp.com/ci/fattach/get/4774269/1466063702/redirect/1/filename/BT%20Smart%20Hub...
You will either need to see if there is anything in the manual or just poke around in the advanced network settings.
