yy
Message 1 of 3
Can anyone interpret this trace for me please
I've had an ongoing issue for about 10 months which looks to me like data loss at peak times. I've got BT working on this but it's a slow and painful process. Outbound tracert from me to an IP address are fine and show slow times but no data loss. I've just done a couple of reverse Trace Routes (Tracert) i.e. in to my public IP rather than out from my computer and got the results below. What I don't know is whether they are reaching me and being blocked by the firewall or whether they are failing before they get to me. An IP lookup shows the last successful  addresses are BT infrastructure servers but I can't tell whether they are at my local exchange or not. Thanks in advance.
Here are the 2 sets of results:
Test 1 - Run by a friend
Tracing route to host86-150-49-122.range86-150.btcentralplus.com [86.150.49.122]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  192.168.0.1
  2    39 ms    37 ms    38 ms  cr4.clber.uk.easynet.net [87.87.253.223]
  3    33 ms    33 ms    33 ms  fe3-1-3.ar11.bllon.uk.easynet.net [82.111.96.81]
  4    34 ms    32 ms    33 ms  te0-2-0-2.er11.thlon.ov.easynet.net [89.200.131.89]
  5    34 ms    34 ms    33 ms  linx7.ukcore.bt.net [195.66.224.56]
  6    48 ms    44 ms    74 ms  core1-te-0-3-1-0.ealing.ukcore.bt.net [62.172.102.2]
  7    38 ms    37 ms    37 ms  acc1-10GigE-0-1-0-0.l-far.21cn-ipp.bt.net [109.159.249.16]
  8    39 ms    38 ms    38 ms  109.159.249.100
  9    36 ms    37 ms    37 ms  213.120.176.177
 10    40 ms    45 ms    37 ms  213.120.176.21
 11    44 ms    46 ms    41 ms  213.120.177.25
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
Test 3 - Conducted from the internet
http://centralops.net/co/Traceroute.aspx
Tracing route to 86.150.49.122 [86.150.49.122]...
hop
rtt
rtt
rtt
ip address
fully qualified domain name
1
1
1
1
70.84.211.97
61.d3.5446.static.theplanet.com
2
1
0
0
70.87.254.1
po101.dsr01.dllstx5.networklayer.com
3
1
1
1
70.85.127.105
po51.dsr01.dllstx3.networklayer.com
4
0
0
0
70.87.253.85
e8-3.ibr03.dllstx3.networklayer.com
5
0
0
0
209.66.99.89
209.66.99.89.available.above.net
6
1
0
0
64.125.27.73
xe-0-1-0.cr1.dfw2.us.above.net
7
1
0
0
64.125.30.78
xe-1-0-0.cr2.dfw2.us.above.net
8
6
6
6
64.125.31.122
xe-4-2-0.cr2.iah1.us.above.net
9
33
57
34
64.125.28.49
xe-2-1-0.cr2.dca2.us.above.net
10
106
133
107
64.125.24.42
xe-4-1-0.mpr1.lhr3.uk.above.net
11
106
107
106
64.125.28.38
so-1-0-0.mpr1.lhr2.uk.above.net
12
107
108
109
64.125.27.150
xe-1-1-0.mpr1.lhr1.uk.above.net
13
116
107
107
195.66.224.69
linx1.ukcore.bt.net
14
112
112
111
62.6.200.102
core2-gig0-10-0-4.ilford.ukcore.bt.net
15
184
140
109
109.159.249.14
acc1-10gige-0-7-0-3.l-far.21cn-ipp.bt.net
16
109
109
110
109.159.249.85
17
109
109
109
213.120.176.177
18
110
109
110
213.120.176.21
19
131
168
213.120.177.9
20
21
22
23
Trace aborted
-- end --
2 REPLIES 2
Geoff93
Recognised Expert
Message 2 of 3
Re: Can anyone interpret this trace for me please
At which point do your outbound trace and inbound trace cross? That might give a clue as to how far from your public Ip address the inbound trace is failing.
yy
Message 3 of 3
 Here is my outbound tracert. I guess that hop 2 is my local exchange. There is no direct match between the IPs outbound and inbound. Hop 5 and 6 on this trace below are within 1 digit of hop 10 and hop 9 respectively of the first of the reverse traces above. I'm not an expert but guess this means they are likely to be co-located? And not my local exchange unless it takes 5 hops to get out of my exchange onto the BT infrastructure.
traceroute to 199.217.10.36 (199.217.10.36), 64 hops max, 52 byte packets
 1  api (192.168.1.254)  0.896 ms  0.635 ms  0.633 ms
 2  217.32.145.136 (217.32.145.136)  22.803 ms  24.074 ms  25.768 ms
 3  217.32.145.206 (217.32.145.206)  25.868 ms  25.140 ms  24.855 ms
 4  213.120.177.10 (213.120.177.10)  23.579 ms  23.575 ms  23.913 ms
 5  213.120.176.22 (213.120.176.22)  23.895 ms  24.465 ms  23.703 ms
 6  213.120.176.178 (213.120.176.178)  24.890 ms  23.638 ms  24.422 ms
 7  acc1-10gige-0-7-0-5.l-far.21cn-ipp.bt.net (109.159.249.86)  23.800 ms
    acc1-10gige-0-2-0-6.l-far.21cn-ipp.bt.net (109.159.249.101)  24.836 ms
    acc1-10gige-0-1-0-5.l-far.21cn-ipp.bt.net (109.159.249.82)  24.035 ms
 8  core1-te0-1-0-0.ealing.ukcore.bt.net (109.159.249.21)  26.865 ms
    core2-te0-1-0-0.ilford.ukcore.bt.net (109.159.249.23)  28.352 ms
    core1-te0-15-0-2.ealing.ukcore.bt.net (109.159.249.17)  27.069 ms
 9  core1-xe1-1-0.redbus.ukcore.bt.net (62.6.200.101)  24.961 ms
    core1-xe0-0-0.redbus.ukcore.bt.net (62.6.200.73)  26.039 ms  25.040 ms
10  ge-2-1-0.mpr1.lhr2.uk.above.net (195.66.224.76)  27.001 ms  26.359 ms  26.868 ms
11  ge-3-0-0.mpr1.lhr2.uk.above.net (64.125.28.126)  25.717 ms  39.982 ms  26.313 ms
12  so-0-1-0.mpr1.dca2.us.above.net (64.125.27.57)  99.724 ms  98.703 ms  99.029 ms
13  xe-0-3-0.cr1.dca2.us.above.net (64.125.29.17)  99.676 ms  98.223 ms  99.004 ms
14  xe-0-2-0.cr1.iah1.us.above.net (64.125.25.114)  126.086 ms  125.555 ms  125.492 ms
15  xe-1-3-0.cr1.lax112.us.above.net (64.125.26.122)  157.246 ms  157.818 ms  157.267 ms
16  xe-0-2-0.cr1.sjc2.us.above.net (64.125.26.26)  166.464 ms  165.509 ms  165.713 ms
17  xe-1-0-0.cr2.sjc2.us.above.net (64.125.30.138)  164.870 ms  165.932 ms  172.025 ms
18  xe-0-1-0.er2.sjc2.us.above.net (64.125.28.21)  165.686 ms  165.177 ms  165.077 ms
19  209.249.49.10.available.above.net (209.249.49.10)  165.920 ms  166.861 ms  165.738 ms
20  ip10-178.esignal.com (199.217.10.178)  167.362 ms  166.201 ms  167.331 ms
21  ip10-140.esignal.com (199.217.10.140)  166.171 ms  165.839 ms  165.510 ms
22  * * *
23  ip225-4.esignal.com (216.23.225.4)  167.897 ms *  167.373 ms
