Croxy
Message 1 of 17
Can not connect using to-link Archer VR600
I have spent a couple of very frustrating hours trying to set up my to-link Archer VR600 to replace my HH5. I am using the TP-Link Tether App to do the initial set up. I am selecting BT_VDSL as my ISP, connection type PPPoE, username: bthomehub@btbroadband.com and password: bt
However it never manages to establish an internet connection!!! I have also checked and I’m on the latest firmware version. Any help would be greatly appreciated... Thanks.
Tags (1)
16 REPLIES 16
licquorice
Message 2 of 17
Re: Can not connect using to-link Archer VR600
Silly question, do you have an Infinity connection or standard broadband?
Croxy
Message 3 of 17
Infinity connection
DavidCo
Expert
Message 4 of 17
It should not matter but have you tried
broadbanduser@btbroadband.com
licquorice
Message 5 of 17
The wizard should set everything up, but just check VLAN has been set to 101
Liam_
Recognised Expert
Message 6 of 17
You could try a reset of the TP-Link and this time put the details in manually in the Internet settings page.  Remember to put in VLAN ID     101.  It's sometimes missed.
Yep.  What @licquorice said as I was typing.
Croxy
Message 7 of 17
The VLAN ID is set to 101 already. Everything I have read on forums says it should work but it doesn’t... I haven’t tried changing the username to broadbanduser@btbroadband.com. Worth a go?
licquorice
Message 8 of 17
Are you getting DSL connectivity but just no internet or no DSL connectivity?
Croxy
Message 9 of 17
Sorry for silly question but how do I know if I have DSL connectivity? I believe I have DSL connectivity. I know if I plug the DSL cable back into my HH5 I get the internet
Liam_
Recognised Expert
Message 10 of 17
Only thing left is try a factory reset of the TP-Link and put the settings back manually don't try the Wizard app thing.
