Message 1 of 5
Can someone help explain my router stats please .
Product code:Smart Hub 2
Firmware version:v0.24.04.11017-BT
Firmware updated:Wed Jan 20 08:47:02 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:2 days,03 Hours02 Mins35 Secs
Data rate:268 Kbps / 73.935 Mbps
Maximum data rate:334 Kbps / 76.015 Mbps
Noise margin:6.3 / 6.4
Line attenuation:2.7 / 12.5
Signal attenuation:2.6 / 12.6
4 REPLIES 4
Message 2 of 5
Re: Can someone help explain my router stats please .
there is something wrong with your up speed
does your landline phone have a dial tone?  if ok then try 1 factory reset by pressing the recessed button on back and holding 20/30 secs until hub lights flash  once hub connects to internet hub light blue then make sure you turn off smart setup in hub manager
after can you repost stats
Message 3 of 5
@imjolly  thanks I've tried most things but nothing seems to fix anything,  I've recently switched to bt from sky on the 20th I have been dealing with this for months and the phone line was out in November and had it fixed but still terrible connection.
Message 4 of 5
so if you dial 17070 option 2 is there a lot of noise as line should be silent.  if noisy then phone CS 150 or 0800800150 from mobile and get engineer visit  report phone fault not broadband
Message 5 of 5
@imjolly thanks so much they found fault on the line now , I just hope it gets fixed properly this time , thanks for your time and help
