Borodin
Message 1 of 2
Can someone please advise.........
I was having some bizarre BT network problems which technical guys advise can only be a result of my power pack not working properly. I have now had a new one installed (£25)...so we shall see....
Don't know if this is significant but when I look at my network centre details  it shows me two BT hubs.....they are identical in all properties (icon shape differs though)  except for the unique identifier details. One begins uuid:   DSLF_BTHomeHub2.0A and the other begins with uuid:UPnP_BTHomeHub2.0A
What is the difference between UPnP and DSLF and should I have both listed ??
Many thanks....
1 REPLY 1
submarinex1
Message 2 of 2
Re: Can someone please advise.........
i cant tell you why, but i have same thing. but the universal plug and play is handy on things that use it to have less chance of problems, things like consoles and some software that uses it.
my belkin router never worked with anything upnp but my bt hub it all worked straight away.
