scotbott
Message 1 of 2
Can someone tell me what this is
this is on my bill do not understand this as i have not opted for caller display can some one tell me what it is or means please.
Minimum calls fee
BT Caller Display
28 Sep 10
The minimum calls have not been made. To avoid future charges, make 6
chargeable or inclusive calls per quarter or more with BT
£7.77
Total one-off charges
thanx scot
1 REPLY 1
hamish72
Recognised Expert
Message 2 of 2
Re: Can someone tell me what this is
Its in the terms and conditions some where if your calls are with some other provider or you don't use land line for calls then the charge is for some things (cant remember exactly what ) which are otherwise in your package for free
this might help     http://community.bt.com/t5/Bills-Call-Packages/minimum-calls-fee/m-p/28900
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
