Fahim711
Message 1 of 9
Can't Connect To BT Openzone
Hi,
I am trying to connect to BTwifi on my iphone 5 but I'm not able to do connect to any BTwifi. So I'm on settings I see BTwifi when I select it it doesn't connect. It tries connecting for a few seconds but then it stops.
So if anyone can help me out or tell me if I'm doing something wrong here
Thanks for your help in advance
8 REPLIES 8
gg30340
Message 2 of 9
Re: Can't Connect To BT Openzone
See link for connecting to BTWifi
http://www.btwifi.com/help/login-with-bt/
If that doesn't work do a search of the forum as there are numerous threads how to connect an iphone.
Fahim711
Message 3 of 9
I know how to connect.. But problem is that I'm not getting the landing page
gg30340
Message 4 of 9
When you connect are you then opening your browser or are you waiting for it to open?
Fahim711
Message 5 of 9
Both.. I've tired waiting for it but nothing happens and I've tried opening safari and noting happens.. But when I say 'connect' I don't think it's fully connected.. It has a tick beside the wifi name BTopenzone but then like 5 seconds later it disappears
gg30340
Message 6 of 9
Have you tried "forgetting" any BTWifi-Fon, Openzone connections that are showing on your phone then re-start the phone and try connecting?
Have you tried the BTWifi app?
Fahim711
Message 7 of 9
Yes.. Forgotten the network and restarted phone many times
Alexis1969
Message 8 of 9
I'm having exactly the same problem. Any luck yet Fahim?
Fahim711
Message 9 of 9
Nope.. I've been able to open the loading page now where it asks for login.. But now I can't login with my details which I am 100% sure they're correct.. So now I've just given up connecting to it
