Message 21 of 25
Re: Can't access any websites! :(
Sounds like HH is knackered.
Have you tried plugging laptop (if you have one) direct into modem and setting up a PPPoE connection?
Message 22 of 25
HH is brand new and everything else can connect to it fine so maybe its something to do with the device? I'll try that though, thanks. I'll let you know if I can get a connection from that.
Message 23 of 25
Hi guys, right I decided to reformat my device in the end. I purchased a copy of Windows 7 and put that on there. This has now solved the issue. Thank you both very much for your help.
Message 24 of 25
Hi coutts99 It cannot be a faulty hub as the OP has stated it is only one device that will not connect
Message 25 of 25
Hi that's great to know you have resolved it it had to be a corruption somewhere as all your other devices were ok
do post back if you ever need any more help
