legitimise_sailing
Distinguished Expert
Message 41 of 48
Re: Can't access the Online Player, nobody can help
Try a different browser
To say thanks for a helpful answer, please click the white star
Indrid
Message 42 of 48
A maze of errors now.
VC025, then VC019. Cleared cache as the FAQ said for VC019.  This gave VC010 "too many simultaneous streams".  I had 0 streams.
Now it's back to VC025 after refresh.  Have tried three browsers all with the same errors.  Hopefully I can get it working for Saturday.
legitimise_sailing
Message 43 of 48
er... it is Saturday
What operating system?
Indrid
Message 44 of 48
I meant by match time.
Windows 7 x64
legitimise_sailing
Message 45 of 48
I was just highlighting that it's now just hours away.
Did you do the 4 things?
1. Update your video drivers
2. Update your clock and 24 hour format
3. Run the Silverlight fixit http://support.microsoft.com/kb/2608523
4. Delete mspr.hds http://mike-thomson.com/blog/?p=210
Indrid
Message 46 of 48
Yeah been through all the steps in the sticky.
Now I consistently get VC019.  Cleared all my browing data from all browsers multiple times.  Argh.  So close!
Indrid
Message 47 of 48
Well I woke up this morning and tried the player and it's working.  Not sure what happened, but I don't care.  Quality is more than reasonable too, looking forward to the match.
legitimise_sailing
Message 48 of 48
That's great news, enjoy the match!
