Newbie
Message 1 of 5
Can't change BTHome Hub IP Address
Hi Guys,
I'm new to BT Broadband and still getting to grips with the BTHH interface.
I need to change the IP and Gateway address of my BTHH to 192.168.0.x but it says that address range isn't allowed.
Any idea why please?
I've got equipment on my network that runs on the 0.x range and would rather change the BTHH address to match than change the 126 devices to the 1.x range.
Thanks in advance.
CheekyD
4 REPLIES 4
Message 2 of 5
Re: Can't change BTHome Hub IP Address
Hi and welcome!
Good luck with changing the address; BT 'fixed' it so that the hub's IP couldn't be amended.
Kyle
If you found my post helpful, please give Kudos on the left!
Recognised Expert
Message 3 of 5
@CheekyD wrote:
Hi Guys,
Thanks in advance.
CheekyD
I don't use a Homehub but this link may help?
How to change the working IP range of a V2 hub
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Message 4 of 5
Hi,
You can change it from the advanced settings of the Hub
Tags (1)
Newbie
Message 5 of 5
@gavaskarss
Yes you can but no you can't.
It says you can't change the IP to range 192.168.0.x
