garygriffiths999
Message 1 of 2
Can't connect 2 xbox360's to homehub 2
Hi,
Both myself and my son have xbox360's, both are in upstairs bedrooms. When he is connected on live, playing with his friends mine will not connect and it doesn't matter how many times i try.
My son has the older whire version and i have the newer 360s black version with built in wireless.
I have spoken to the xbox helpline who have said the problem is to do with my homehub and both xbox's are fighting for the one ip address. Is this correct?  And how do i go about rectifying it.
Any help would be gratefully received.
1 REPLY 1
NilSatisOptimum
Recognised Expert
Message 2 of 2
Re: Can't connect 2 xbox360's to homehub 2
hi,
You could check this site out- http://www.unofficialguidetolive.co.uk/faqs/63-two-xboxes-using-one-router-internet-connection
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
