Hero9989
Message 1 of 15
Can't connect 3DS and android devices to HomeHub 3
Ok, devices that won't connect are:
Nintendo 3DS
Advent Vega Android Tablet
Orange San Francisco Android Phone
My 3DS connected when I first bought it. but now I can't connect to the homehub at all, when I scan for wireless networks, where the Homehub should be, it just shows an empty router, doesn't show the SSID or security type.
With the two android devices, they show the SSID ok, but they don't recognise the security type, they show the network as open (when it actually has WPA2 encryption) - thus it doesn't give me anywhere to put in the passphrase
Anyone else had any trouble with these and know of any fixes?
14 REPLIES 14
sicknote00
Message 2 of 15
Re: Can't connect 3DS and android devices to HomeHub 3
have you tried pressing the wifi button on the back of the HH3 ?
Q. There is smoke coming out of my open reach box... so can I have a new one.
A. Sorry sir, The fault is showing at the exchange so your box should be ok.
BRING BACK UK CALL CENTRES!!!!!
Hero9989
Message 3 of 15
It's not that wifi is off. It's working fine with a pile of other devices (blu ray player, PS3, 360, laptop). It's just those 3 devices that won't connect
sicknote00
Message 4 of 15
i wasnt suggesting that your wifi was off...sometimes pressing that button helps find other devices.
Hero9989
Message 5 of 15
Oh right, sorry, I tried it and it didn't do anything, thanks for the suggestion though. I found something that says pressing the tiny reset button on the back can fix it. So I'll try that and report back if I still need help..
Hero9989
Message 6 of 15
Problem sorted 🙂 for now
No idea what was actually wrong with it, maybe something just got itself into a knot or something. But hey 🙂
sicknote00
Message 7 of 15
sometimes interference from other wifi devices around your area can cause this...HH3 is normally on auto search for the best channel on wifi,and pressing the wifi button or reseting can resolve the problem,glad you have sorted it
rich101088
Newbie
Message 8 of 15
I am having this same problem, it connects after i reset but then a few minutes later it wont, i get the error code 003-1099, ive tried everything, tearing my hair out!
Chibihobo
Newbie
Message 9 of 15
I Think I was having this problem too and only just figured it out.
My 3DS couldnt even see my BTHomeHub3
My wifi networks channel was set to automatic (as default on the homehub3) and had chosen channel 11. My guess is that the 3DS doesn't have a European wifi card so cant interact with wireless devices on channel 11. Changed my homehubs channel to 9 and everything works perfectly.
Hope this helps
monkeymagik
Newbie
Message 10 of 15
Hi
I am having the same problem and it is sooooo annoying. If I reset the router, or change the channel then the 3ds will connect for a while, but when I next restart the 3ds, it cant see the ssid of the bt home hub 3.
I have tried everythiung but to no avail. Any help ?
