Message 1 of 4
Can' t connect BT Advanced Digital Home Phone to Asus RT-AC86U
hi all,
I'm trying to setup my new BT Advanced Digital Home Phone but for the life of me i cannot figure out how to set it up on my Asus RT-AC86U router. it has options for WPS etc but it just wont pick anything up when trying to pair.
Any help with this would be appreciated as i currently cannot use my phone and have no intention of using the BT hub.
3 REPLIES 3
Message 2 of 4
Re: Can' t connect BT Advanced Digital Home Phone to Asus RT-AC86U
The BT digital phone connects with Dect not wifi hence why it connects to hub which is a dect base station and your Asus is not
Message 3 of 4
thanks for that, couldn't find any info about that anywhere. can you get boxes that just handle dect or do you need get a router that is compatible?
Message 4 of 4
You only option is to use the BT supplied Smart Hub 2, as that has the built in base station.
