Message 1 of 2
Can't connect to BTWifi-with-FON
Hi
Every time i try to  connect to BTWifi-with-FON  i get teh folllowing message :
" windows was unable to connect to BTWifi-with-FON "
I have never had problems connecting to the hotspot that i use at home.
I dont use a hub i only use this same hotpot
The signal strength is excellent and it has an orange thing on it with an exclamation mark but i've always had that and i just connnect and wait 5 minutes and then everythign is ok
For the last 3 days i havent been able to connect at all  and sometimes i havent even ben able to see the BTWIFI-FON
Its works perfectly on  2 other PCs
This is the only computer that cant connect and sometimes cant see it
another thing i should mention is that before when i was connecting it would wait a much longer time before not connecting or connecting but this time it tells me i cant connect in 2 seconds like its not even trying.
This is an image of what i see before trying to connect to FON
This is an image of the message i get when i try to connect
Thanks a lot for your time
James
1 REPLY 1
Message 2 of 2
Re: Can't connect to BTWifi-with-FON
Assuming it is not a problem on your computer, it may be that who ever owns the BTWifi hotspot needs to reset their Homehub. This can only be done by the owner and can not be done by BT. Unless you know the owner of the Homehub and can ask them to reset it there is nothing that can be done.
