tarbat
Message 1 of 6
Can't find channels 507 - 509
Got a letter in the post today from BT telling me that I can watch BT Sport1, BT Sport2, and ESPN on channels 507, 508, 509 on my BT TV.
But I can't find these channels on my BT TV box. I've done a retune several times, but these channels don't appear.
5 REPLIES 5
Moderator-Retired
Message 2 of 6
Re: Can't find channels 507 - 509
Which box have you got? A BT Vision box or a Youview box?
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Message 3 of 6
Pc and IPad work fine, but no channels on Youview box. Eventually got thru to call centre after loads of checks done, I was told that BT have configured my box incorrectly and needed to call 0800 800 801 because my order for BT Sport had been incorrectly configured. Interesting thou I did see all the IP channels on the box before they implemented my order for BT sport. Rang the said number and was cut off after 25mins of waiting
tarbat
Message 4 of 6
I've got a BT Youview box. I've tried channel rescans, and software download, but still no channels 507 - 509.
Distinguished Guru
Message 5 of 6
Do you have infinity?
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
bonsai
Message 6 of 6
As Stuart asked, do you have Infinity? If so and you can't see the sports channels at 507-512 and the extra channels at 413 onwards in the guide then check the following
Go to Youview>Settings>System Information>Software versions and check the ISP Configuration.
It should be 29, if it is 28 the box is not configured for multicast channels and needs a software update which has to be initiated from the BT end.
If you don't then sport / extra channels are not available to you on the Youview box
