wolfmanii
Message 1 of 6
Can't find the BT Usage Monitor - How do you get it added?
Hi,
    I can see from the forum threads that there is a BT Usage Monitor that you can access through My BT. However, when I look at my 'My BT' account, there is no sign of the usage monitor.
Any help in getting access to it would be appreciated.
5 REPLIES 5
Storm_Force
Message 2 of 6
Re: Can't find the BT Usage Monitor - How do you get it added?
Go to my BT
Select your landline / broadband account
Look down the page where it says manage your services
Click on the broadband tab
You should then see the link to check your usage
wolfmanii
Message 3 of 6
where is the  broadband tab? I do not seem to have this when I scroll down to the manage your services
Storm_Force
Message 4 of 6
Distinguished Guru
Message 5 of 6
Hi.
If you want a short link, I've got bookmarked :-
https://www.bt.com/appsyouraccount/secure/cyahub.do
hence you enter your bt.com login (unless already logged in), and follow the instructions Storm_Force gave.
wolfmanii
Message 6 of 6
Nope, mine looks nothing like this. Is it because I am on BTinfinity?
I have no tab options just phone options even though the account says 'Broadband and Calls' and these Phone options just say there is an error and cannot display information.
