Newbie
Message 1 of 24
Can't get Fibre but my parents can.
Hi,
I have been waiting a long time to get faster broadband and our green cabinet was finally upgraded just before Xmas. However, when I checked my details Fibre options weren't available for me but my parents were able to upgrade. They are literally situated across the street from me.
Both of us are connected to the same cabinet. Could there be a database error that is prohibiting me from getting Fibre? I read this could be a possibility from other posters.
Thanks,
Michael
23 REPLIES 23
Message 2 of 24
Re: Can't get Fibre but my parents can.
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 24
How do you know you're connected to the same cabinet? Does it show the same cabinet when you put both yours and your parents number into the checker above?
Newbie
Message 4 of 24
Hi Webby,
Yes it shows the same cabinet for both numbers.
Message 5 of 24
 Then post your results
Newbie
Message 6 of 24
Hi imjolly,
Please see below,
Telephone Number my house on Exchange WARINGSTOWN is served by Cabinet 15
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+Up to 2--1 to 3.5Available
WBC ADSL 2+ Annex MUp to 2Up to 0.51 to 3.5Available
ADSL MaxUp to 1.5--1 to 2.5Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
BETUp to 2----Available
Telephone Number parent's house on Exchange WARINGSTOWN is served by Cabinet 15
Featured Products
Availability Date
  HighLowHighLow
FTTC Range A (Clean)15.48.81.20.8--Available
FTTC Range B (Impacted)11.93.81.20.5--Available
Other Offerings
I have basically been checking the two numbers since the cabinet was upgraded. I checked with my service provider and they find this bizarre. Though they mentioned the fibre ports could be all used up....but that wouldn't make sense either as I have never been successful in checking my number for fibre.
Message 7 of 24
the most likely answer is you are too far from your cabinet to get fibre service
Message 8 of 24
you really need to post on your own ISP forum - there is no more of a link from here to openreach than there is from your own forum
you can write to openreach and see if you can get them to update database  https://www.formwize.com/run/survey3.cfm?id=7214&embed
Newbie
Message 9 of 24
Hi john46,
That couldn't be right since my parents can get it and they are further away from the cabinet as they are like 20m further down the road from me.
Newbie
Message 10 of 24
Thanks imjolly,
It's my first posting and I wasn't sure where to post. I wasn't hoping a mod would be able to assist with this. I have already filled in that form so hopefully I will get a reply soon.
