Epyon
Message 1 of 15
Can't order BT infinity someone help please?
Hi i'm trying to buy bt infinity
now it says its not available in my area though i have sky fibre optic right now and my neighbour has BT infinity
i did try and phone and explain but the guy would not have it
any way to speak to someone so they can force the order?
i'm currently one of skys customers with the half throughput fault and i am sick of theres excuses.
14 REPLIES 14
Message 2 of 15
Re: Can't order BT infinity someone help please?
you would need to bring your line back to BT first
Epyon
Message 3 of 15
So order a line with BT? once the line is fitted order BT infinity?
Surely theres an easier way?
Epyon
Message 4 of 15
Also on the postcode checker it says i can't get nither can my next door
come on bt U NO WANT NEW CUSTOMERS?
Phoned sales
got a hold of the manager and he says if the system says no then even changing you're line back to BT won't make a difference for god sake stupid openreach systems.......
Message 5 of 15
infinity can only be provided on a BT line that is why it is not showing up on the checker also the postcode check is very basic and could include several cabinets some of which may not be enabled as you are on sky fibre service that like infinity comes from the same street cabinet and provided by Openreach to all isp's BT retail is just a provider like sky they can only sell you infinity if the database shows you have an active BT line
Epyon
Message 6 of 15
Well i went to test that theory
did a check on my next doors line who has infinity
it says he can't get it even though he has it
thing is the postcode checker said i could get it like 2 months ago now it says i can't
this was what i did get
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 75.7Mbps and upstream line speed of 20Mbps
Now it says nothing about fibre
BT systems are junk.
fortytwo
Message 7 of 15
Do Sky do full LLU then? You can order Sky fibre with no line at all and they will install (ok get Openreach to install) one.
Even LLUd lines can be returned to BT without the need to order a new line but I suspect doing that could disrupt the Sky fibre that is in place.
I suspect this will turn out to be an Openreach data error which I had myself in which case the mods here may be able to help.
Epyon
Message 8 of 15
Well if a mod sees this please help me out i really want to get rid of this junk sky fttc Cat Wink
Message 9 of 15
You'll have to contact the mods directly if you want them to look into it mate.
hifistud
Message 10 of 15
You do realise that, effectively, the only thing that will change is who bills you, don't you? Both Sky and BT fibre systems are installed and maintained by Openreach - they use the same backbone, same cabinets, same gear in the cabinets and the same copper pair going to your house. If you have a fault issue with Sky, you'll keep it with BT - once your connection gets to the cab, that's all she wrote - the phone line is immaterial.
