Message 1 of 6
Can't order Infinity although openreach says cab accepting orders
Just wondering if anyone can help with what to do. I am connected to cabinet 32 on Chichester exchange. Openreach confirms that the cabinet is accepting orders (see below), but the wholesale checker does not show it as available. It is a fairly long line though syncs at min of 1.5Mbits and has been as high as 3Mbit/s. Is my line too long, or is the database not updated somewhere? If the latter, how can I get this looked at?
Many thanks
Openreach response:
Thank you for your enquiry regarding the Chichester Exchange, cabinet 32.
Our systems indicate that cabinet 32 has now gone live and is currently accepting orders.
Regards,
Julie
BT Wholesale Checker:
Telephone Number 01243XXXXXX on Exchange CHICHESTER is served by Cabinet 32
Available Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Featured Products
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available
ADSL Max Up to 1 -- 0.75 to 2.5 Available
WBC Fixed Rate 0.5 -- -- Available
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: Can't order Infinity although openreach says cab accepting orders
Hi and welcome
The BT Wholesale page should indicate results a bit like this if you can get FTTC.
As you can see by my results it states WBC FTTC is available
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 6
Thanks - yes - I'm aware what it should look like if I could order.  But Openreach (via nga.enquiries@openreach.co.uk) says the cabinet is live and accepting orders (as obviously also the exchange), and yet I cannot make an order as FTTC does not appear as available on the BT wholesale checker.  So trying to understand if this is an insoluble line length issue or maybe the database is wrong, and how one goes about getting that checked? Thanks
Guru
Message 4 of 6
It's possible the cabinet is currently full and will need another line card to support more connections.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Sage
Message 5 of 6
Contact the mods, they'll get back to you within 3 days with an answer for you.
Message 6 of 6
Thanks. Have contacted the mods.
